跳转到主内容
Nintendo 2DS Rear Panel Replacement
你所需要的
  1. Nintendo 2DS Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Remove the ten Phillips screws attaching the rear panel.
  2. Nintendo 2DS Rear Panel Replacement: 步骤 2 中的图像 1,1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  3. Nintendo 2DS Rear Panel Replacement: 步骤 3 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
结论
9等其他人完成本指南。
Fina Beauchamp
于01/12/15注册
2,948 声望
创作了6篇指南
团队
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G1
4 名成员
创作了35篇指南
2条评论
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
Evergreen - 回复
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
Leo Ochoa -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 119
总计 12,627
