跳转到主内容
Nintendo 2DS Motherboard Replacement
你所需要的
  1. Nintendo 2DS Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Motherboard Replacement: 步骤 2 中的图像 1,2 Nintendo 2DS Motherboard Replacement: 步骤 2 中的图像 2,2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 1,3 Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 2,3 Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. Nintendo 2DS Motherboard Replacement, Rear Panel: 步骤 4 中的图像 1,1
    • Remove the ten Phillips screws attaching the rear panel.
  5. Nintendo 2DS Motherboard Replacement: 步骤 5 中的图像 1,1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  6. Nintendo 2DS Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
  7. Nintendo 2DS Motherboard Replacement, Remove Side Panels: 步骤 7 中的图像 1,2 Nintendo 2DS Motherboard Replacement, Remove Side Panels: 步骤 7 中的图像 2,2
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
  8. Nintendo 2DS Motherboard Replacement, Unscrew Motherboard: 步骤 8 中的图像 1,1
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
  9. Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 1,3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 2,3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 3,3
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
  10. Nintendo 2DS Motherboard Replacement, Remove Motherboard: 步骤 10 中的图像 1,2 Nintendo 2DS Motherboard Replacement, Remove Motherboard: 步骤 10 中的图像 2,2
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
结论
34等其他人完成本指南。
Fina Beauchamp
于01/12/15注册
3,189 声望
创作了6篇指南
团队
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G1
4 名成员
创作了35篇指南
13指南评论
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - 回复
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Demon09 - 回复
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - 回复
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David -
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - 回复
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 184
过去 30 天: 833
总计 63,501
