跳转到主内容
Nintendo 2DS Battery Replacement
你所需要的
  1. Nintendo 2DS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: 步骤 2 中的图像 1,2 Nintendo 2DS Battery Replacement: 步骤 2 中的图像 2,2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: 步骤 3 中的图像 1,3 Nintendo 2DS Battery Replacement: 步骤 3 中的图像 2,3 Nintendo 2DS Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
结论
40等其他人完成本指南。
Fina Beauchamp
于01/12/15注册
3,189 声望
创作了6篇指南
团队
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G1
4 名成员
创作了35篇指南
7指南评论
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - 回复
This didnt help my problem
Artemy Matveev - 回复
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - 回复
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 147
过去 30 天: 760
总计 56,406
