跳转到主内容
Ninja Ultima BL810 Power Plug Replacement
你所需要的
  1. Ninja Ultima BL810 Power Plug Replacement, Power Plug: 步骤 1 中的图像 1,3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: 步骤 1 中的图像 2,3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: 步骤 1 中的图像 3,3
    • Unscrew the Phillips #0 11mm screws.
    • Unscrew the Torx Security #10 11mm screw.
  2. Ninja Ultima BL810 Power Plug Replacement: 步骤 2 中的图像 1,2 Ninja Ultima BL810 Power Plug Replacement: 步骤 2 中的图像 2,2
    • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
    • Pull the bottom covering off of the blender.
  3. Ninja Ultima BL810 Power Plug Replacement: 步骤 3 中的图像 1,2 Ninja Ultima BL810 Power Plug Replacement: 步骤 3 中的图像 2,2
    • Unscrew the two Phillips #2 9mm screws.
    • Remove the plastic block.
  4. Ninja Ultima BL810 Power Plug Replacement: 步骤 4 中的图像 1,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 4 中的图像 2,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 4 中的图像 3,3
    • Unscrew the four Phillips #2 11mm screws.
    • Remove the plastic covers.
    • Removing the top cover and then rotating the bottom cover into the same orientation works best.
  5. Ninja Ultima BL810 Power Plug Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three Phillips #2 9mm screws.
    • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
  6. Ninja Ultima BL810 Power Plug Replacement: 步骤 6 中的图像 1,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 6 中的图像 2,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 6 中的图像 3,3
    • Pull the power cord through as shown to create slack.
    • Remove plastic casing by lifting upwards.
  7. Ninja Ultima BL810 Power Plug Replacement: 步骤 7 中的图像 1,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 7 中的图像 2,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 7 中的图像 3,3
    • Follow the power plug cords to find the right plastic caps.
    • Squeeze the caps with pliers to loosen the grip.
    • Pull the plastic caps off the twisted wires.
  8. Ninja Ultima BL810 Power Plug Replacement: 步骤 8 中的图像 1,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 8 中的图像 2,3 Ninja Ultima BL810 Power Plug Replacement: 步骤 8 中的图像 3,3
    • Untwist the two wires from each other and pull the zip tie off.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S9-G4, Banghart Fall 2017 Cal Poly, Team S9-G4, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 610
