跳转到主内容
Ninja Professional Blender BL660 Suction Cups on Base Replacement
你所需要的
  1. Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: 步骤 1 中的图像 1,2 Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: 步骤 1 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 5 screws holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Suction Cups on Base Replacement: 步骤 2 中的图像 1,2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: 步骤 2 中的图像 2,2
    • Turn the base panel upside down to reveal the suction cup feet.
  3. Ninja Professional Blender BL660 Suction Cups on Base Replacement: 步骤 3 中的图像 1,1
    • Push the stopper on the suction cup foot through the bottom panel using the iFixit plastic opening tool.
  4. Ninja Professional Blender BL660 Suction Cups on Base Replacement: 步骤 4 中的图像 1,2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: 步骤 4 中的图像 2,2
    • Once stopper has passed through the bottom panel, pull suction cup foot out.
    • Replace suction cup feet as needed.
    • Ninja does not sell suction cup feet. You will need to obtain them from other third party vendors.
结论
一条评论
Where did you get the suction cups from?
camoramirez - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 59
总计 4,842
