跳转到主内容
Ninja Professional Blender BL660 Fan Replacement
你所需要的
  1. Ninja Professional Blender BL660 Fan Replacement, Blender Base: 步骤 1 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement, Blender Base: 步骤 1 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Fan Replacement: 步骤 2 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Fan Replacement: 步骤 3 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Fan Replacement: 步骤 4 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Fan Replacement: 步骤 5 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement: 步骤 5 中的图像 2,2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Fan Replacement, Fan: 步骤 6 中的图像 1,1
    • Use a wrench or a pair of pliers to help remove the nut on top of the fan. Holding the fan itself will help make the process easier.
    • The fan blades are sharp. Handle with care. Using a paper towel or cloth while handling is recommended.
  7. Ninja Professional Blender BL660 Fan Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to loosen the washer.
  8. Ninja Professional Blender BL660 Fan Replacement: 步骤 8 中的图像 1,2 Ninja Professional Blender BL660 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove washer then slide the fan off the screw.
    • Replace the fan as needed.
    • The fan has a keyed hole, thus it fits on the shaft in a specific way. Ensure you put it on correctly.
结论
一条评论
I did that but the other fan is the one that is lock and do not turn on. The white one in the middle. How can I fix it.
Tania Polanco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 746
