跳转到主内容
Ninja NJ600 Fan Replacement
你所需要的
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: 步骤 1 中的图像 1,2 Ninja NJ600 Fan Replacement, Blender Base Cover: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: 步骤 2 中的图像 1,2 Ninja NJ600 Fan Replacement: 步骤 2 中的图像 2,2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: 步骤 3 中的图像 1,3 Ninja NJ600 Fan Replacement: 步骤 3 中的图像 2,3 Ninja NJ600 Fan Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: 步骤 4 中的图像 1,1
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: 步骤 5 中的图像 1,1
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: 步骤 6 中的图像 1,2 Ninja NJ600 Fan Replacement: 步骤 6 中的图像 2,2
    • Slide the washer and fan off of the screw.
结论
Ryan Heller
于04/01/15注册
107 声望
撰写一个指南
团队
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,333
