跳转到主内容
Ninja Mega Kitchen System BL770 Cooling Fan Replacement
你所需要的
  1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: 步骤 1 中的图像 1,2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: 步骤 3 中的图像 1,3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: 步骤 3 中的图像 2,3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: 步骤 5 中的图像 1,2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: 步骤 5 中的图像 2,2
    • Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
    • Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 742
