跳转到主内容
Ninja Master Prep QB900B button replacement
你所需要的
  1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: 步骤 1 中的图像 1,1
    • Place the blender to the side.
  2. Ninja Master Prep QB900B button replacement: 步骤 2 中的图像 1,2 Ninja Master Prep QB900B button replacement: 步骤 2 中的图像 2,2
    • Remove the two highlighted screws with a Phillips #2 Screw Driver
    • Gently pull off the top.
  3. Ninja Master Prep QB900B button replacement, Button: 步骤 3 中的图像 1,1
    • Remove the highlighted screws.
  4. Ninja Master Prep QB900B button replacement: 步骤 4 中的图像 1,1
    • Pull out the highlighted spring.
    • Now wash the button with soap and water, and follow the guide backwards to reassemble.
结论
2等其他人完成本指南。
Kamal Taha
于08/27/15注册
679 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Fall 2015 USF Tampa, Team 1-3, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G3
3 名成员
创作了5篇指南
2指南评论
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - 回复
turns out it was a security torx. how annoying.
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 2,177
