简介
You will learn how to remove the motor from the base to check for frayed wires and/or loose screws.
你所需要的
Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
how do you get the top wheel off that spins the blender cup device itself? The part that goes through the plastic housing from the motor?
2等其他人完成本指南。
