跳转到主内容
Ninja Kitchen System Pulse Fan Replacement
你所需要的
  1. Ninja Kitchen System Pulse Fan Replacement, Base Disassembly: 步骤 1 中的图像 1,1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Fan Replacement, Fan: 步骤 3 中的图像 1,1
    • Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
    • Place this screw on the magnetic mat.
  4. Ninja Kitchen System Pulse Fan Replacement: 步骤 4 中的图像 1,2 Ninja Kitchen System Pulse Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the fan from the motor by gently pulling upwards.
    • Be careful as to not damage any wires when removing the fan.
    • Set the fan to the side.
结论
3等其他人完成本指南。
Cameron Just
于01/20/16注册
391 声望
创作了3篇指南
团队
USF Tampa, Team 15-1, Remmell Spring 2016 USF Tampa, Team 15-1, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 901
