简介
If the motor in your Ninja Foodi SP101 is malfunctioning, it may be difficult for your food to reach desired temperatures. Follow this guide to quickly replace your Ninja Foodi SP101 motor.
你所需要的
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
Open the bottom door.
Remove the five 8 mm screws located on the control panel side using a Phillips #1 screwdriver.
结论
