跳转到主内容
Ninja Coffee Bar CF086 Water Pump Replacement
你所需要的
  1. Ninja Coffee Bar CF086 Water Pump Replacement, Water Heating Element: 步骤 1 中的图像 1,2 Ninja Coffee Bar CF086 Water Pump Replacement, Water Heating Element: 步骤 1 中的图像 2,2
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 2 中的图像 1,1
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 3 中的图像 1,1
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 4 中的图像 1,1
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 5 中的图像 1,1
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 6 中的图像 1,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 6 中的图像 2,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 6 中的图像 3,3
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 7 中的图像 1,2 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 7 中的图像 2,2
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 8 中的图像 1,2 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 8 中的图像 2,2
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 9 中的图像 1,2 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 9 中的图像 2,2
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 10 中的图像 1,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 10 中的图像 2,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 10 中的图像 3,3
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 11 中的图像 1,1
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
  12. Ninja Coffee Bar CF086 Water Pump Replacement, Water Pump: 步骤 12 中的图像 1,3 Ninja Coffee Bar CF086 Water Pump Replacement, Water Pump: 步骤 12 中的图像 2,3 Ninja Coffee Bar CF086 Water Pump Replacement, Water Pump: 步骤 12 中的图像 3,3
    • Locate the water pump in the interior of your device.
    • Squeeze and remove the clamps securing the tubes that are connected to the side of the water pump.
  13. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 13 中的图像 1,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 13 中的图像 2,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 13 中的图像 3,3
    • Remove the tubes attached to the side of the water pump.
  14. Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 14 中的图像 1,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 14 中的图像 2,3 Ninja Coffee Bar CF086 Water Pump Replacement: 步骤 14 中的图像 3,3
    • Trace the three wires leading out of the water pump until you find the connector linking them to the wires in your device.
    • Detach the connector and remove the water pump.
结论
2等其他人完成本指南。
David Ton
于10/02/17注册
630 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Thompson Fall 2017 USF Tampa, Team S1-G5, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 6,203
