跳转到主内容
Ninja Coffee Bar CF080 Heated Plate Replacement
你所需要的
  1. Ninja Coffee Bar CF080 Heated Plate Replacement, Heated Plate: 步骤 1 中的图像 1,1
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 2 中的图像 1,2 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 2 中的图像 2,2
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 3 中的图像 1,3 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 3 中的图像 2,3 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 3 中的图像 3,3
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 4 中的图像 1,3 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 4 中的图像 2,3 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 4 中的图像 3,3
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 5 中的图像 1,1
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 6 中的图像 1,1
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 7 中的图像 1,2 Ninja Coffee Bar CF080 Heated Plate Replacement: 步骤 7 中的图像 2,2
    • Remove the heated plate from the machine with easy glide.
结论
另外一个人完成了本指南。
Elizabeth Nguyen
于09/11/17注册
416 声望
创作了3篇指南
团队
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S1G1
4 名成员
创作了5篇指南
一条评论
Where do you get a replacement plate at?
Timothy Sick - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 11
总计 800
