跳转到主内容
Ninja Coffee Bar CF080 Brewer Head Replacement
你所需要的
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: 步骤 1 中的图像 1,1
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 2 中的图像 1,1
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 3 中的图像 1,3 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 3 中的图像 2,3 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 3 中的图像 3,3
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 4 中的图像 1,1
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 5 中的图像 1,3 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 5 中的图像 2,3 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 5 中的图像 3,3
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 6 中的图像 1,1
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 7 中的图像 1,2 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 7 中的图像 2,2
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 8 中的图像 1,1
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 9 中的图像 1,1
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 10 中的图像 1,2 Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 10 中的图像 2,2
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: 步骤 11 中的图像 1,1
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
结论
另外一个人完成了本指南。
Elizabeth Nguyen
于09/11/17注册
416 声望
创作了3篇指南
团队
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 994
