跳转到主内容
加入维修社区 - 创建账户
Ninja Coffee Bar® Single-Serve System Water Heater Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: 步骤 1 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: 步骤 1 中的图像 2,2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 2 中的图像 1,1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 3 中的图像 1,1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 4 中的图像 1,1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: 步骤 5 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: 步骤 5 中的图像 2,2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 6 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 6 中的图像 2,2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 7 中的图像 1,1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 8 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 8 中的图像 2,2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 9 中的图像 1,1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 10 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 步骤 10 中的图像 2,2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
结论
CJ Berg
于11/05/18注册
444 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G4
3 名成员
创作了10篇指南
1指南评论
Where can I buy the water heater?
lrstorey1 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 47
总计 1,597
