跳转到主内容
Ninja Coffee Bar® Single-Serve System Power Cable Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: 步骤 1 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: 步骤 1 中的图像 2,2
    • Unscrew the eight 6mm #1 Phillips head screws off the bottom panel.
    • Lift lower panel up while passing the power cord through the opening.
  2. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 步骤 2 中的图像 1,1
    • Loosen two 6mm #1 Phillips head and remove clamp holding power cable.
  3. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 步骤 3 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 步骤 3 中的图像 2,2
    • Pull the power cable out exposing the two crimped ends.
    • Using a wire stripper/crimping tool, uncrimp wires.
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
结论
另外一个人完成了本指南。
CJ Berg
于11/05/18注册
444 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 459
