跳转到主内容
加入维修社区 - 创建账户
Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: 步骤 1 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: 步骤 1 中的图像 2,2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 2 中的图像 1,1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 3 中的图像 1,1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 4 中的图像 1,1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: 步骤 5 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: 步骤 5 中的图像 2,2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 6 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 6 中的图像 2,2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 7 中的图像 1,1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 8 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 8 中的图像 2,2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 9 中的图像 1,1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 10 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: 步骤 10 中的图像 2,2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
  11. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Hot Water Tubing: 步骤 11 中的图像 1,1
    • Squeeze connector and pull tubing away from heater.
    • Inspect tubing for damage and/or weak spots and replace if necessary.
结论
Kyle Gustafson
于11/04/18注册
85 声望
撰写一个指南
团队
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G4
3 名成员
创作了10篇指南
2指南评论
what size tubing does this require?
Lemmiwinks Rules - 回复 分享
Hi Kyle,
Thanks for this. I’m having trouble getting the top to separate. Any suggestions?
S. D. G. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 55
总计 2,777
