跳转到主内容
Ninja Coffee Bar® Single-Serve System Frother Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: 步骤 1 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: 步骤 1 中的图像 2,2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 2 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 2 中的图像 2,2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 3 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 3 中的图像 2,2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 4 中的图像 1,3 Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 4 中的图像 2,3 Ninja Coffee Bar® Single-Serve System Frother Replacement: 步骤 4 中的图像 3,3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
结论
CJ Berg
于11/05/18注册
444 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G4
3 名成员
创作了5篇指南
一条评论
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 1,509
