跳转到主内容
Nikon N80 Viewfinder Replacement
你所需要的
  1. Nikon N80 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 1,1
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Viewfinder Replacement: 步骤 2 中的图像 1,3 Nikon N80 Viewfinder Replacement: 步骤 2 中的图像 2,3 Nikon N80 Viewfinder Replacement: 步骤 2 中的图像 3,3
    • Remove the four 4.8mm screws on the top section of the camera using a PH00 Phillips screwdriver.
    • Two are located by the viewfinder and and the other two are on each side of the camera.
  3. Nikon N80 Viewfinder Replacement: 步骤 3 中的图像 1,2 Nikon N80 Viewfinder Replacement: 步骤 3 中的图像 2,2
    • Rotate the camera so the bottom plate is accessible.
    • Remove the seven 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
    • Separate the bottom plate.
  4. Nikon N80 Viewfinder Replacement: 步骤 4 中的图像 1,1
    • Remove the five silver 4.8mm screws on the lens mount using a PH00 Phillips screwdriver.
    • Extract the lens mount.
  5. Nikon N80 Viewfinder Replacement: 步骤 5 中的图像 1,3 Nikon N80 Viewfinder Replacement: 步骤 5 中的图像 2,3 Nikon N80 Viewfinder Replacement: 步骤 5 中的图像 3,3
    • Remove the seven 4.8mm screws on front camera plate using a PH00 Phillips screwdriver.
    • One is located on the battery chamber side of the camera, two are next to the film door release lever, two are located below the "Nikon" logo, and the last two are located above the "Nikon" logo in the Speedlight compartment.
  6. Nikon N80 Viewfinder Replacement: 步骤 6 中的图像 1,1
    • Separate the three front camera plates from the camera.
  7. Nikon N80 Viewfinder Replacement: 步骤 7 中的图像 1,1
    • Gently disconnect the top section of the camera from the body.
    • Don't pull the top section off too hard or the wire and ribbon within the camera may disconnect.
  8. Nikon N80 Viewfinder Replacement: 步骤 8 中的图像 1,1
    • Remove the two 4.8mm screws next to the viewfinder with a PH00 Phillips screwdriver.
  9. Nikon N80 Viewfinder Replacement: 步骤 9 中的图像 1,2 Nikon N80 Viewfinder Replacement: 步骤 9 中的图像 2,2
    • Pull out the viewfinder gently.
结论
另外一个人完成了本指南。
Maegan Viloria
于09/14/15注册
717 声望
创作了5篇指南
团队
CSU Fullerton, Team 1-7, Bruce Fall 2015 CSU Fullerton, Team 1-7, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G7
3 名成员
创作了10篇指南
一条评论
This is a great guide, thank you!
Test Test - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 40
总计 2,631
