本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
你所需要的
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
5等其他人完成本指南。
一条评论
where can I order the "3 loose pieces and the ring that goes in under the bayonet mount?
