跳转到主内容
Nikon N2000 (F301) Communication Board Replacement
你所需要的
  1. Nikon N2000 (F301) Communication Board Replacement, Lens Mount: 步骤 1 中的图像 1,1
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Nikon N2000 (F301) Communication Board Replacement: 步骤 2 中的图像 1,1
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
  3. Nikon N2000 (F301) Communication Board Replacement, Communication Board: 步骤 3 中的图像 1,1
    • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  4. Nikon N2000 (F301) Communication Board Replacement: 步骤 4 中的图像 1,1
    • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  5. Nikon N2000 (F301) Communication Board Replacement: 步骤 5 中的图像 1,3 Nikon N2000 (F301) Communication Board Replacement: 步骤 5 中的图像 2,3 Nikon N2000 (F301) Communication Board Replacement: 步骤 5 中的图像 3,3
    • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  6. Nikon N2000 (F301) Communication Board Replacement: 步骤 6 中的图像 1,1
    • Remove the front case from the camera.
    • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  7. Nikon N2000 (F301) Communication Board Replacement: 步骤 7 中的图像 1,1
    • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  8. Nikon N2000 (F301) Communication Board Replacement: 步骤 8 中的图像 1,1
    • Desolder the wires and remove them from the communication board.
    • Note: If you are unfamiliar with soldering techniques, click here for a guide.
结论
5等其他人完成本指南。
Zachary Phillips
于04/08/11注册
247 声望
创作了5篇指南
团队
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G26
3 名成员
创作了12篇指南
3条评论
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
John Chapple - 回复
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
Miles Kosik -
Is there a way to remove the plasticzek top cover, as comment above says, the knobs prevents me from removing this part. My plastic cover is broken and I want to change it for a new one, is there a way?
Filip N - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 54
总计 6,082
