跳转到主内容
Nikon N2000 (F301) Battery Compartment Replacement
你所需要的
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: 步骤 2 中的图像 1,1
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: 步骤 3 中的图像 1,1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: 步骤 4 中的图像 1,1
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: 步骤 5 中的图像 1,1
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
结论
4等其他人完成本指南。
Zachary Phillips
于04/08/11注册
247 声望
创作了5篇指南
团队
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G26
3 名成员
创作了12篇指南
一条评论
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 123
总计 17,277
