跳转到主内容
Nikon D90 Tripod Thread Plate Replacement
你所需要的
  1. Nikon D90 Tripod Thread Plate Replacement, Bottom Casing: 步骤 1 中的图像 1,1
    • Turn the camera so the bottom casing is facing up.
  2. Nikon D90 Tripod Thread Plate Replacement, Removing  Screws from the Bottom Casing: 步骤 2 中的图像 1,2 Nikon D90 Tripod Thread Plate Replacement, Removing  Screws from the Bottom Casing: 步骤 2 中的图像 2,2
    • Next, use a PH00 screwdriver to remove the screws from the bottom casing.
    • Remove the four 5.3 mm Phillips screws.
    • Remove the three other 6.3 mm Phillips screws.
    • Be careful not to strip the screws.
  3. Nikon D90 Tripod Thread Plate Replacement, Removing the Bottom Case: 步骤 3 中的图像 1,2 Nikon D90 Tripod Thread Plate Replacement, Removing the Bottom Case: 步骤 3 中的图像 2,2
    • Next, use a plastic opening tool and carefully pop off the bottom case.
    • Then, lift and remove the bottom case.
  4. Nikon D90 Tripod Thread Plate Replacement, Removing Screws: 步骤 4 中的图像 1,2 Nikon D90 Tripod Thread Plate Replacement, Removing Screws: 步骤 4 中的图像 2,2
    • Next, remove the five 5.3 mm Phillips screws.
  5. Nikon D90 Tripod Thread Plate Replacement, Taking Out the Plate: 步骤 5 中的图像 1,2 Nikon D90 Tripod Thread Plate Replacement, Taking Out the Plate: 步骤 5 中的图像 2,2
    • Now use a plastic opening tool and carefully pop off the metal tripod thread plate.
    • Be careful to not pull on any wires under the thread plate.
  6. Nikon D90 Tripod Thread Plate Replacement, Removing the Plate from the Camera: 步骤 6 中的图像 1,2 Nikon D90 Tripod Thread Plate Replacement, Removing the Plate from the Camera: 步骤 6 中的图像 2,2
    • Carefully wiggle the yellow metal tab to remove the plate.
    • Be careful not to pull hard and damage any other pieces.
结论
Andrew
于10/24/14注册
180 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G7
3 名成员
创作了6篇指南
2条评论
كاميرا لاتعمل تماما شرت كت
hamdyalchip - 回复
Thanks for the guide, this gives me a good idea how to go about this on a D3000.
However: “Next, use a PH00 screwdriver to remove the screws from the bottom casing. Remove the Phillips screws. Be careful not to strip the screws.”
Nikon does not use Phillips screws, they are JIS (Japanese Industrial Standard) screws.
They are not the same and to not have the “cam out” feature of Phillips which is designed to prevent heads being sheared off.
The easiest way to strip JIS screws is by using a Phillips screwdriver.
Use the correct JIS screwdriver and you’ll have no problem.
Cheers
Mark Roy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 22
总计 3,529
