跳转到主内容
加入维修社区 - 创建账户
Nikon D90 Flash Hinge Spring Replacement
你所需要的
  1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 步骤 1 中的图像 1,3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 步骤 1 中的图像 2,3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 步骤 1 中的图像 3,3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: 步骤 2 中的图像 1,2 Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: 步骤 2 中的图像 2,2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 步骤 3 中的图像 1,3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 步骤 3 中的图像 2,3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 步骤 3 中的图像 3,3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: 步骤 4 中的图像 1,2 Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: 步骤 4 中的图像 2,2
    • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
  5. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: 步骤 5 中的图像 1,2 Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: 步骤 5 中的图像 2,2
    • Use a plastic opening tool and carefully pry up the spring arm.
    • Doing this with release the pressure of the spring.
  6. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: 步骤 6 中的图像 1,2 Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: 步骤 6 中的图像 2,2
    • Finish removing the screw holding the spring in place.
    • The spring can now be removed and replaced.
结论
另外一个人完成了本指南。
Matthew Grota
于10/16/14注册
598 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G7
3 名成员
创作了6篇指南
2指南评论
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - 回复
My flash won't stay down. I think the piece that clips in to keep it closed may have broken. Is there a way to fix?
Linda Wick - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 55
总计 4,641
