简介
With a few simple tools and parts, this guide will help you replace your broken or burnt out bulb on the Nikon D90 camera. Be careful not to strip the screws as you disassemble the camera. In addition, be careful not to break the bulb or cut yourself on a broken bulb while you are disassembling the camera.
你所需要的
Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
Use a plastic opening tool and carefully pry open the top casing of the flash.
Then, lift off the top casing of the flash.
Remove the rubber stopper on the left and right side of the bulb.
Separate the rubber stopper from the white and black tape.
The bulb can now be slid out and replaced.
8等其他人完成本指南。
2条评论
Hi guys do you know where to get this bulb?please help
