跳转到主内容
Nikon D80 Rear LCD Screen Replacement
你所需要的
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 1,3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 2,3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 3,3
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 1,3 Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 2,3 Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Rear LCD Screen Replacement: 步骤 3 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  4. Nikon D80 Rear LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  5. Nikon D80 Rear LCD Screen Replacement: 步骤 5 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
结论
另外一个人完成了本指南。
Sara Martin
于10/09/17注册
586 声望
创作了4篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G1
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 3,757
