跳转到主内容
Nikon D80 Main Board Replacement
你所需要的
  1. Nikon D80 Main Board Replacement, Main Board: 步骤 1 中的图像 1,2 Nikon D80 Main Board Replacement, Main Board: 步骤 1 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: 步骤 2 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 2 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 2 中的图像 3,3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: 步骤 3 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 3 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: 步骤 4 中的图像 1,2 Nikon D80 Main Board Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: 步骤 6 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 6 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 6 中的图像 3,3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
结论
2等其他人完成本指南。
Sara Martin
于10/09/17注册
577 声望
创作了4篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G1
4 名成员
创作了5篇指南
一条评论
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 2,207
