跳转到主内容
Nikon D7100 Headphone/Microphone Replacement
你所需要的
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: 步骤 3 中的图像 1,1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: 步骤 4 中的图像 1,1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: 步骤 5 中的图像 1,1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: 步骤 6 中的图像 1,1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: 步骤 7 中的图像 1,1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: 步骤 8 中的图像 1,1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: 步骤 9 中的图像 1,2 Nikon D7100 Headphone/Microphone Replacement: 步骤 9 中的图像 2,2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: 步骤 10 中的图像 1,1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: 步骤 11 中的图像 1,1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: 步骤 12 中的图像 1,2 Nikon D7100 Headphone/Microphone Replacement: 步骤 12 中的图像 2,2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: 步骤 13 中的图像 1,1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: 步骤 14 中的图像 1,1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: 步骤 15 中的图像 1,1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: 步骤 16 中的图像 1,1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: 步骤 17 中的图像 1,1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: 步骤 18 中的图像 1,1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
结论
另外一个人完成了本指南。
Wesley Eveld
于02/20/18注册
731 声望
创作了4篇指南
团队
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,026
