本指南有最近更改,您可查看未经巡查的最新版本。
简介
Remove the rear cover assembly to access the LCD and other components.
你所需要的
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
11等其他人完成本指南。
一条评论
Thanks for the instructions, but I’m an old man (74) with not much strength these days, and so I am having MUCH difficulty removing these TINY screws even with a jeweler’s screwdriver (the smallest Phillips driver I have. I’ll have to look for a smaller set of screwdrivers, and perhaps a younger, stronger, more adept person to help.
But thanks for the instructions and for the knowhow. MY specialties are writing (awards for writing), photography (awards for photography), acting, poetry, computer building/repair, and so on.
Thanks again.
John Weatherly, Seattle, WA
