当前版本的文档还未经巡查,您可以查看最新的已查核版本。
在D70的下方用指尖向下拨动电池释放卡的中心。
打开电池仓。
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
Use your fingernail to flip up the ZIF cable retaining flap on each socket.
Be sure you are prying up the retaining flap, not the socket.
Pull the ribbon cable straight out of its socket.
Use your fingernails to carefully pull the ZIF cable lock away from its socket.
Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Grab the memory compression board by its edges at the position shown in the first picture.
Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
Use your fingernail to carefully flip up the ZIF cable retaining flap for the ribbon cable socket near the front cover.
Be sure you are prying up on the movable cable retaining flap, not the socket itself.
Use a pair of tweezers to carefully pull the ribbon cable out of its socket.
Use your fingernail to flip up the ZIF cable retaining flap on the socket near the battery opening.
Use a pair of tweezers to pull the ribbon cable out of its socket.
Carefully de-solder the eight leads boxed in red.
Do not heat up the board excessively while de-soldering. There are many heat sensitive components mounted to the DC/DC board.
There are two black leads that look very similar. The thinner of the two connects closer to the center of the board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
