跳转到主内容
加入维修社区 - 创建账户
Nikon D70 CF Slot Replacement
你所需要的
  1. Nikon D70 CF Slot Replacement, Rear Cover Assembly: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  2. Nikon D70 CF Slot Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  3. Nikon D70 CF Slot Replacement: 步骤 3 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  4. Nikon D70 CF Slot Replacement: 步骤 4 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the sides of the rear cover away from the body of the D70.
  5. Nikon D70 CF Slot Replacement: 步骤 5 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 5 中的图像 2,2
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  6. Nikon D70 CF Slot Replacement, D70 CF card slot replacement: 步骤 6 中的图像 1,2 Nikon D70 CF Slot Replacement, D70 CF card slot replacement: 步骤 6 中的图像 2,2
    • Remove the two Phillips screws securing the holder of the CF Card Slot.
  7. Nikon D70 CF Slot Replacement: 步骤 7 中的图像 1,1
    • Peel of the Foil securing the Flexcable.
  8. Nikon D70 CF Slot Replacement: 步骤 8 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use Tweezers to open the locking on the ribbon cable socket.
  9. Nikon D70 CF Slot Replacement: 步骤 9 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 9 中的图像 2,2
    • Pull the ribbon cable out of its socket.
  10. Nikon D70 CF Slot Replacement: 步骤 10 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 10 中的图像 2,2
    • Carefully fold the Pull the ribbon cable towards the CF Slot
  11. Nikon D70 CF Slot Replacement: 步骤 11 中的图像 1,1
    • Pull the Slot out of the body.
  12. Nikon D70 CF Slot Replacement: 步骤 12 中的图像 1,2 Nikon D70 CF Slot Replacement: 步骤 12 中的图像 2,2
    • Remove the two Phillips screws to separate the Holder from the Slot.
结论
24等其他人完成本指南。
joergkihm
于06/04/12注册
812 声望
撰写一个指南
6指南评论
Mine has a pin broken off. Where do I get a replacement?
Don Wirth - 回复
Hello,
Thanks to your help, I was able to replace it easily.
Many Thanks from France
Yan Elie - 回复
How do i change out the board with the pins…… second hand cam someone bent alot of pins
intimadationrc - 回复
I can order board or can i order the whole cf ?
intimadationrc -
You can find them on ebay real easy. both full assemblies and just the board with the pins
Steve Ancona -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 117
总计 29,062
