跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace the CCD sensor board.
  1. Use your finger tip to pull the battery release tab toward the center of the D70.
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Pull the battery out of the D70.
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Remove the following eight screws securing the bottom cover to the D70:
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Carefully pull the bottom cover to separate it from the body of the D70. Remove the bottom cover from the D70.
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Remove the four ZIF ribbon cables highlighted in red by using the following procedure: Use your fingernail to flip up the ZIF cable retaining flap on each socket. Be sure you are prying up the retaining flap, not the socket.
    • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
    • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
    • Be sure you are prying up the retaining flap, not the socket.
    • Pull the ribbon cable straight out of its socket.
  6. Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
    • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
    • It is not necessary to completely remove this piece of tape.
  7. Use your fingernails to carefully pull the ZIF cable lock away from its socket. Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop. Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
    • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
    • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
    • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  8. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  9. Be sure not to lose the small iron core around the DC-In ribbon cable.
    • Be sure not to lose the small iron core around the DC-In ribbon cable.
  10. Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
    • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
  11. Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
    • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
  12. Grab the memory compression board by its edges at the position shown in the first picture. Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
    • Grab the memory compression board by its edges at the position shown in the first picture.
    • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
  13. De-route the two leads routed over the connector boxed in yellow. Use your thumbnails to push the connector out of its socket.
    • De-route the two leads routed over the connector boxed in yellow.
    • Use your thumbnails to push the connector out of its socket.
  14. Remove the two Phillips screws securing the grip side of the rear cover to the D70.
    • Remove the two Phillips screws securing the grip side of the rear cover to the D70.
  15. Remove the two Phillips screws securing the DC-In side of the rear cover to the D70.
    • Remove the two Phillips screws securing the DC-In side of the rear cover to the D70.
  16. Carefully pull the sides of the rear cover away from the body of the D70. Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • Carefully pull the sides of the rear cover away from the body of the D70.
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
  17. At this point, the capacitor is visible and its exposed contacts are boxed in red. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  18. Peel back the piece of tape connecting the iron core around the CCD board ribbon cable to the inner case.
    • Peel back the piece of tape connecting the iron core around the CCD board ribbon cable to the inner case.
  19. Remove the four 4.8 mm Phillips screws securing the CCD board to the D70.
    • Remove the four 4.8 mm Phillips screws securing the CCD board to the D70.
  20. Remove the CCD board from the D70, minding any cables that may get caught. When reinstalling the CCD board, be sure to press the alignment posts on the right and bottom edges of the board up against the guides machined into the case while tightening the screws down.
    • Remove the CCD board from the D70, minding any cables that may get caught.
    • When reinstalling the CCD board, be sure to press the alignment posts on the right and bottom edges of the board up against the guides machined into the case while tightening the screws down.
结论
24等其他人完成本指南。
Great instructions.
One important note: When re-installing the CCD board ribbon cable into the CCD board, the cable will go into the connector about 2mm and feel like it's seated. However, the cable must go 3mm-4mm into the connector. Otherwise, you will get a "This Card Cannot Be Used" error message each time you depress the shutter button.
Ross Edmond - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 16
过去的30天: 50
总计 29,566
