跳转到主内容
Nikon D610 Battery Replacement
你所需要的
  1. Nikon D610 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: 步骤 2 中的图像 1,3 Nikon D610 Battery Replacement: 步骤 2 中的图像 2,3 Nikon D610 Battery Replacement: 步骤 2 中的图像 3,3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: 步骤 3 中的图像 1,2 Nikon D610 Battery Replacement: 步骤 3 中的图像 2,2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
结论
Daniel Eagan
于02/10/16注册
606 声望
创作了5篇指南
团队
USF Tampa, Team 4-4, Lacy Spring 2016 USF Tampa, Team 4-4, Lacy Spring 2016 的会员
USFT-LACY-S16S4G4
3 名成员
创作了6篇指南
一条评论
This is my kind of fixing )
Loic - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,421
