跳转到主内容
Nikon D5100 Battery Door Replacement
你所需要的
  1. Nikon D5100 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,3 Nikon D5100 Battery Door Replacement, Battery Door: 步骤 1 中的图像 2,3 Nikon D5100 Battery Door Replacement, Battery Door: 步骤 1 中的图像 3,3
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: 步骤 2 中的图像 1,3 Nikon D5100 Battery Door Replacement: 步骤 2 中的图像 2,3 Nikon D5100 Battery Door Replacement: 步骤 2 中的图像 3,3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: 步骤 3 中的图像 1,3 Nikon D5100 Battery Door Replacement: 步骤 3 中的图像 2,3 Nikon D5100 Battery Door Replacement: 步骤 3 中的图像 3,3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: 步骤 4 中的图像 1,1
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: 步骤 5 中的图像 1,2 Nikon D5100 Battery Door Replacement: 步骤 5 中的图像 2,2
    • Turn on the camera to check that the battery is properly secure.
终点
另外一个人完成了本指南。
Michelle Tran
于02/24/15注册
128 声望
撰写一个指南
团队
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 的会员
CPSU-GREEN-W15S23G1
4 名成员
创作了4篇指南
一条评论
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 51
总计 2,940
