本指南有最近更改,您可查看未经巡查的最新版本。
简介
Need to clean out every last speck of dust? Scratched your sensor filter? Swapping out the filter for a custom modification? This guide can help.
你所需要的
Unscrew the eight Phillips #00 screws on the back panel:
Two 2.5x6mm screws above the screen.
One 3x6mm screw on the upper part of each side (two total; right side shown).
One 3x7.5mm screw on the lower part of each side (two total).
Two 3x4.5mm screws on the bottom.
Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
Disconnect a seventh ribbon cable in the lower-right corner.
3等其他人完成本指南。
