跳转到主内容
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,2 Nikon D5000 Battery Door Replacement, Battery Door: 步骤 1 中的图像 2,2
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: 步骤 2 中的图像 1,2 Nikon D5000 Battery Door Replacement: 步骤 2 中的图像 2,2
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
结论
2等其他人完成本指南。
Jacob Rardin
于04/14/14注册
1,390 声望
创作了6篇指南
团队
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G28
4 名成员
创作了7篇指南
一条评论
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 85
总计 4,913
