简介
This is the steps to remove the top assembly of the camera.
你所需要的
Remove the Memory Card(s) from the camera
Remove the Battery from the Camera, and close the battery compartment cover
Remove the 2 screws beside the memory slots, then close the cover.
Note: make sure to remove the memory cards first!
Remove the 2 screws under the rubber grip part by peeling back the rubber grip
Try not to damage the double sided adhesive under the rubber.
Remove the 2 screws under the rubber pad marked in red.
Try not to damage the double-sided adhesive under the rubber.
Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
The 3rd screw is not attached to the the side panel, but is attached to the top. This part of the guide is for removing the side panel, so that screw did not need to be removed. There is another step that is for removing that screw to release the rear panel.
I have edited the step to add that comment.
Lift out the assembly panel, it should come free without much force.
May open the panel to release it.
Remove the 4 screws holding the plate to the bottom.
Remove the bottom plate
Remove the 4 screws (1 was under the plate removed under the last step)
Remove the screw under the grip, if it has not been removed doing a previous step
Carefully pull the back plate off the camera
There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
To release the cables by flipping up the tap on the side away from the cable
When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
The LCD cable does have less slack, so is easier to release first, and reconnect last.
Any How to for removing the ribbon cables safely and affective
The ribbon cables have latched covers which the catches flip up and release the cables from the motherboard.
Wolphin -
Carefully remove the Rubber grip from the camera
Careful to not damage the double-sided adhesive
Remove the diopter cap from the end of the diopter (use a flat head or pry tool)
Un-screw the phillips screw from the diopter
When reconnecting, make sure the cap is seated in correctly and the double sided tape is not damaged (or replace)
There is a notch which the indicator has to seat into, or it will not sit down correctly when it is reinstalled.
Remove the screw under the top assembly, had been hidden by the grip.
Remove the 2 screws from the bottom of the mirror box
Remove the lens or lenscap prior to doing this step to gain access, then reattach.
Remove the screw from beside the accessory socket
Disconnect the 2 ribbon cables from the main board (Red boxes)
Lift the black tabs above the cables to release the cables
When reseating the cables, make sure they are fully seated before closing the locking tab
Disconnect the wifi sub-board with the wifi cable from the main board (Blue Box) or gently disconnect the wifi antenna (Blue circle)
Carefully lift the top assembly free.
Note, there is a thermal pad on the left hand side, almost right under where the strap lug is. Red Box. Careful to not damage it.
Careful of the thermal pad on the left side when placing the top assembly back onto the camera.
另外一个人完成了本指南。
