跳转到主内容
Nikon D40 LCD Screen Replacement
你所需要的
  1. Nikon D40 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon D40 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
  6. Nikon D40 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Detach the ribbon cables on the LCD casing.
  7. Nikon D40 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Be sure to look at the picture to make sure you are removing the correct piece of metal. There should be no glue holding the correct piece to the frame.
  8. Nikon D40 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • You should now be able to remove the LCD screen. Replace it with a new screen.
结论
4等其他人完成本指南。
Gerik Kubiak
于01/21/14注册
327 声望
创作了2篇指南
团队
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G19
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 6,070
