跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will demonstrate the proper procedure to remove the back panel without damaging the internals of the camera so that you can access a variety of the components hidden behind it.
配件
没有特定配件。
  1. Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera. Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  5. While pulling the bottom down, remove the back of the camera.
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
结论
Gerik Kubiak
于2014年01月21日注册
327 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G19
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 82
