跳转到主内容
Nikon D3100 Lens Mounting Ring Reseating/Replacement
你所需要的
  1. Nikon D3100 Lens Mounting Ring Reseating/Replacement, Lens Mounting Ring: 步骤 1 中的图像 1,1
    • Remove the 6 Phillips screws on the front of the lens mounting ring.
  2. Nikon D3100 Lens Mounting Ring Reseating/Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the mounting ring straight up.
    • Three unfastened metal plates lie under the lens mounting ring, be very careful lifting it up as to not disturb them.
  3. Nikon D3100 Lens Mounting Ring Reseating/Replacement: 步骤 3 中的图像 1,2 Nikon D3100 Lens Mounting Ring Reseating/Replacement: 步骤 3 中的图像 2,2
    • Reseat or replace the lens mounting ring and reassemble.
    • The locating pin on the right of the camera will help place the mounting ring properly.
    • The small metal plates marked in the image are not fastened and may displace if the camera if tipped or bumped. Be sure these are properly in place before reassembly.
结论
8等其他人完成本指南。
Taylor
于01/30/15注册
1,165 声望
创作了5篇指南
团队
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G6
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 4,122
