你所需要的
Remove six 3 mm x 2.5 mm Phillips head screws from the bottom of the camera.
Remove three 3 mm x 5.5 mm Phillips head screws from the bottom of the camera near the battery cover.
Lift the battery cover and remove two 3 mm x 5.5 mm Phillips head screws as shown.
Remove the bottom cover.
Remove six 3 mm x 5.5 mm Phillips head screws from around the lens ring and remove the lens ring.
Remove two 2.5 mm x 4 mm Phillips head screws from above the lens ring to allow the front of the camera to be removed.
Lift and remove the grip and the front panel of the camera.
Remove two 3 mm x 4 mm Phillips head screws from where the camera grip was just removed.
Remove one 2 mm x 3 mm Phillips head screw from the same location as above.
Remove one 3 mm x 5.5 mm Phillips head screw from the top right side of the camera shown.
Remove one 3 mm x 3 mm Phillips head screw from the top left side of the camera shown.
Gently lift the top of the camera up to separate it from the main body of the camera. At this point, it will still be connected via wires.
4等其他人完成本指南。
