跳转到主内容
加入维修社区 - 创建账户
Nikon D3000 Motherboard Replacement
你所需要的
    1. Nikon D3000 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Nikon D3000 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
      • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
      • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
      • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
      询问修复机器人
      添加评论
    2. Nikon D3000 Motherboard Replacement: 步骤 2 中的图像 1,3 Nikon D3000 Motherboard Replacement: 步骤 2 中的图像 2,3 Nikon D3000 Motherboard Replacement: 步骤 2 中的图像 3,3
      • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
      • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
      • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
      询问修复机器人
      添加评论
    3. Nikon D3000 Motherboard Replacement: 步骤 3 中的图像 1,2 Nikon D3000 Motherboard Replacement: 步骤 3 中的图像 2,2
      • Use the following process for removing all ribbon connectors.
      • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
      • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
      询问修复机器人
      添加评论
    4. Nikon D3000 Motherboard Replacement: 步骤 4 中的图像 1,2 Nikon D3000 Motherboard Replacement: 步骤 4 中的图像 2,2
      • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
      • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
      • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
      • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
      • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
      询问修复机器人
      添加评论
    5. Nikon D3000 Motherboard Replacement: 步骤 5 中的图像 1,2 Nikon D3000 Motherboard Replacement: 步骤 5 中的图像 2,2
      • Lift the tabs and pull away the ribbon connectors shown .
      • Lift the motherboard and disconnect the grey connector from the bottom.
      • Disconnect and remove the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015 的会员
USFT-MEIER-F15S14G7
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 49
总计 4,911
