跳转到主内容
Nikon D3000 LCD Screen Cover Replacement
你所需要的
  1. Nikon D3000 LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 1,1
    • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove one 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom.
  2. Nikon D3000 LCD Screen Cover Replacement: 步骤 2 中的图像 1,3 Nikon D3000 LCD Screen Cover Replacement: 步骤 2 中的图像 2,3 Nikon D3000 LCD Screen Cover Replacement: 步骤 2 中的图像 3,3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
  3. Nikon D3000 LCD Screen Cover Replacement: 步骤 3 中的图像 1,3 Nikon D3000 LCD Screen Cover Replacement: 步骤 3 中的图像 2,3 Nikon D3000 LCD Screen Cover Replacement: 步骤 3 中的图像 3,3
    • Gently lift the back of the camera off, starting with the top first.
    • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
    • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
  4. Nikon D3000 LCD Screen Cover Replacement: 步骤 4 中的图像 1,2 Nikon D3000 LCD Screen Cover Replacement: 步骤 4 中的图像 2,2
    • Remove six 5 mm x 4mm head screws, then remove the metal plate from the plastic camera backing.
  5. Nikon D3000 LCD Screen Cover Replacement: 步骤 5 中的图像 1,1
    • Tape the buttons down on the front of the plastic camera backing in order to avoid losing them in the process.
    • Use a heat gun on the edges of the LCD screen cover in order to loosen the adhesive.
    • Use the prying tool to separate the LCD screen cover from the plastic camera backing (the LCD screen cover will come out towards the front).
    • Install a new LCD screen cover.
结论
5等其他人完成本指南。
Flor
于08/26/15注册
294 声望
撰写一个指南
团队
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015 的会员
USFT-MEIER-F15S14G7
4 名成员
创作了6篇指南
2指南评论
Where could I find a new LCD screen cover?
Aly Blackmore - 回复
You can find them on eBay.
Mike Roedema - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 34
总计 2,211
