跳转到主内容
Nikon Coolpix S9700 Back Panel Replacement
你所需要的
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix S9700 Back Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 3 中的图像 3,3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix S9700 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: 步骤 5 中的图像 1,2 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S9700 Back Panel Replacement: 步骤 6 中的图像 2,2
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: 步骤 7 中的图像 1,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 7 中的图像 2,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 7 中的图像 3,3
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: 步骤 8 中的图像 1,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 8 中的图像 2,3 Nikon Coolpix S9700 Back Panel Replacement: 步骤 8 中的图像 3,3
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
结论
Matt Staubus
于10/05/16注册
849 声望
创作了5篇指南
团队
USF Tampa, Team 9-5, Lacy Fall 2016 USF Tampa, Team 9-5, Lacy Fall 2016 的会员
USFT-LACY-F16S9G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 1,141
