跳转到主内容
Nikon Coolpix S800c Motherboard Replacement Guide
你所需要的
  1. Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: 步骤 1 中的图像 1,2 Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: 步骤 1 中的图像 2,2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 2 中的图像 1,2 Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 2 中的图像 2,2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Motherboard Replacement Guide, Motherboard: 步骤 3 中的图像 1,1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 4 中的图像 1,1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 5 中的图像 1,1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 6 中的图像 1,3 Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 6 中的图像 2,3 Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 6 中的图像 3,3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 7 中的图像 1,2 Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 7 中的图像 2,2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 8 中的图像 1,2 Nikon Coolpix S800c Motherboard Replacement Guide: 步骤 8 中的图像 2,2
    • Pull the motherboard off of the main body of the camera.
结论
Soldered wires attaching the motherboard to the camera body will need to be disconnected at the motherboard-end and the new wires on the replacement motherboard will need to be soldered on. To reassemble your device, follow these instructions in reverse order.
Kenneth Huynh
于01/30/18注册
133 声望
撰写一个指南
团队
Baylor, Team S2-G6, Johnson Spring 2018 Baylor, Team S2-G6, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 229
