跳转到主内容
Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
你所需要的
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: 步骤 1 中的图像 1,2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: 步骤 1 中的图像 2,2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: 步骤 2 中的图像 1,2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: 步骤 2 中的图像 2,2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
结论
2等其他人完成本指南。
Ilyasah Muhammad
于01/30/18注册
234 声望
创作了2篇指南
团队
Baylor, Team S2-G6, Johnson Spring 2018 Baylor, Team S2-G6, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G6
3 名成员
创作了10篇指南
一条评论
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Brian Capouch - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 421
