跳转到主内容
Nikon Coolpix S7000 Sticky Button Replacement
你所需要的
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix S7000 Sticky Button Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix S7000 Sticky Button Replacement: 步骤 2 中的图像 3,3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S7000 Sticky Button Replacement: 步骤 3 中的图像 2,2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S7000 Sticky Button Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S7000 Sticky Button Replacement: 步骤 4 中的图像 3,3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: 步骤 5 中的图像 1,1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: 步骤 6 中的图像 1,1
结论
另外一个人完成了本指南。
Shannon Beane
于01/10/17注册
324 声望
创作了2篇指南
团队
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 的会员
USFT-LACY-S17S2G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,259
