跳转到主内容
Nikon Coolpix S7000 Shutter Button Replacement
你所需要的
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 1,2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 2,2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S7000 Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S7000 Shutter Button Replacement: 步骤 3 中的图像 2,2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S7000 Shutter Button Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S7000 Shutter Button Replacement: 步骤 4 中的图像 3,3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
结论
团队
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 的会员
USFT-LACY-S17S2G3
4 名成员
创作了10篇指南
一条评论
shutter keeps trying to open. clicks slighly and does not open
Beatrix - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 706
