跳转到主内容
简介
If you notice the camera shutter button isn't depressing or is too easily pressed, you may have to adjust or replace the button or button assembly. This guide will show you how to repair the individual parts that comprise the shutter button.
配件
没有特定配件。
  1. Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver. Screw locations.
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Remove outer camera frames by carefully pulling the frame apart from the body of the camera. Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Once the shutter button assembly is removed from the camera shell,  carefully remove the black tape on the underside of the metal plate. Black tape.
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it. Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover. Locations of the two screws.
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
结论
Nicholas Leon-Schetina
于2017年02月24日注册
110 信誉积分
撰写一个指南
团队
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 的会员
USFT-LACY-S17S2G3
4 名成员
创作了10篇指南
一条评论
shutter keeps trying to open. clicks slighly and does not open
Beatrix - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 499
